Updated on 2025-06-13 GMT+08:00
EIP Bandwidth Size
It specifies the bandwidth size of a shared load balancer. The default value is 1 to 2,000 Mbit/s. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies with the bandwidth range.
  • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
  • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1,000 Mbit/s.
  • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1,000 Mbit/s.
Value Range
From 1 Mbit/s to 2000 Mbit/s
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
