TLS Certificate
It specifies the information about a server certificate used by a listener. Configure either this parameter or tls-certificate-ids. Create a kubernetes.io/tls or IngressTLS secret to store the certificate first.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Configure this parameter to interconnect with the existing certificates.
