Backend Server Response Timeout
It specifies the timeout duration for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
Value Range
1 to 300 seconds
Default Value
60s
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Value range: 1 to 300 (seconds)
Default value: 60s
Only HTTP or HTTPS listeners are supported.
