Updated on 2025-11-11 GMT+08:00
Load Balancer ID
It specifies the ID of the load balancer associated with an ingress. If the load balancer is created automatically, this parameter is configured by the system. If an existing load balancer is used, this parameter can be set to the ID of this load balancer.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Do not configure this parameter when load balancers are automatically created.
