Updated on 2025-06-13 GMT+08:00
Client Request Timeout
It specifies the timeout duration for waiting for a request sent from a client. There are two situations:
  • If the client fails to send a request header to the load balancer within the timeout duration, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
Value Range
From 1 to 300 seconds
Default Value
60 seconds
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
Suggestions
Configure the parameter to a value from 1 to 300 seconds. The default value is 60.
This parameter is only for HTTP and HTTPS listeners.
