vGPU Scheduling
It controls whether to enable the virtualized GPU scheduling. The configuration supports scheduling of segmented and isolated compute and memory of a single GPU.
Value Range
true or false
Default Value
true
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Enable this scheduling by default for GPU-powered clusters. Disable it if GPUs are not used.
