Toleration
If a node is abnormal, the volcano add-on pods will be evicted after a specified period of time. This configuration improves the add-on availability.
By default, the volcano add-on pods will be evicted if the node on which these pods run is unavailable for 60 seconds.
Value Range
Community configurations for taints
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Keep the default settings.
