Platform Version
It specifies the CCE cluster platform version, which is the internal version under the cluster version (version). Platform versions are used to trace iterations in a major cluster version. They are unique within a major cluster version and recounted when the major cluster version changes. The platform version cannot be customized, and when you create a cluster, the latest corresponding platform version is selected automatically.
Value Range
cce.X.Y
- X: internal feature version, indicating changes in features, patches, or OS support in the cluster version. The value starts from 1 and increases monotonically.
- Y: patch version of an internal feature version. It is used only for software package update after the feature version is released. No other modification is involved. The value starts from 0 and increases monotonically.
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Use the latest minor cluster version.
