Updated on 2025-11-11 GMT+08:00
Node Selection
It specifies a common algorithm for selecting nodes. Nodes are scored in simulated resource allocation to find the most suitable node for the current job.
Scoring parameters:
  • nodeaffinity.weight: Pods are scheduled based on node affinity. Default value: 1
  • podaffinity.weight: Pods are scheduled based on pod affinity. Default value: 1
  • leastrequested.weight: Pods are scheduled to the node with the least requested resources. Default value: 1
  • balancedresource.weight: Pods are scheduled to the node with balanced resource allocation. Default value: 1
  • mostrequested.weight: Pods are scheduled to the node with the most requested resources. Default value: 0
  • tainttoleration.weight: Pods are scheduled to the node with a high taint tolerance. Default value: 1
  • imagelocality.weight: Pods are scheduled to the node where the required images exist. Default value: 1
  • selectorspread.weight: Pods are evenly scheduled to different nodes. Default value: 0
  • volumebinding.weight: Pods are scheduled to the node with the local PV delayed binding policy. Default value: 1
  • podtopologyspread.weight: Pods are scheduled based on the pod topology. Default value: 2
Value Range
true: This plugin is enabled. false: This plugin is disabled.
Scoring parameters:
  • nodeaffinity.weight: Enter a positive integer.
  • podaffinity.weight: Enter a positive integer.
  • leastrequested.weight: Enter a positive integer.
  • balancedresource.weight: Enter a positive integer.
  • mostrequested.weight: Enter a positive integer.
  • tainttoleration.weight: Enter a positive integer.
  • imagelocality.weight: Enter a positive integer.
  • selectorspread.weight: Enter a positive integer.
  • volumebinding.weight: Enter a positive integer.
  • podtopologyspread.weight: Enter a positive integer.
Default Value
true
  • nodeaffinity.weight: 1
  • podaffinity.weight: 1
  • leastrequested.weight: 1
  • balancedresource.weight: 1
  • mostrequested.weight: 0
  • tainttoleration.weight: 1
  • imagelocality.weight: 1
  • selectorspread.weight: 0
  • volumebinding.weight: 1
  • podtopologyspread.weight: 2
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Use default settings. For specific requirements, adjust the weights based on your given service scenarios.
Increasing the value of a certain field will make it more influential during node scoring.
nodeorder and binpack magnify the basic scores of nodes based on the corresponding weights. If the weight of a field increases, the corresponding policy will have stronger influence on scoring a node. Other policies will be less influential.
