CPU Management
It provides the CPU management policies, which are used to allocate exclusive CPUs to applications (CPU pinning) to improve application performance and reduce scheduling latency.
The value can be none (or null) or static, and the default value is none.
- If it is set to none (or null), CPU cores will not be exclusively allocated to workload pods. Select this value if you want a large pool of allocatable CPU cores.
- If it is set to static, CPU cores can be exclusively allocated to workload pods. Select this value if your workload is sensitive to latency in CPU cache and scheduling. In a CCE Turbo cluster, this setting is valid only for nodes on which common containers run.
Value Range
none or static
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
