Updated on 2025-11-11 GMT+08:00
IPv4 Service CIDR Block
It is used to configure the Service CIDR block so that containers in the same cluster can access each other.
It specifies the Service CIDR block or the IP address range which kubernetes clusterIP must fall within. It is available only for clusters v1.11.7 and later. If this parameter is not specified during cluster creation, the default value 10.247.0.0/16 is used.
Value Range
None
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
