HPA Synchronization Period
It specifies the period of HPA for synchronizing the number of pods. HPA checks pods and auto scaling policies to determine whether to scale pods. A smaller value will result in a faster auto scaling response and higher CPU load.
Value Range
Greater than or equal to 0
Default Value
15 seconds
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Unless otherwise specified, keep the default settings.
If the value is too small, the manager will respond slowly. If it exceeds the upper limit (153,722,867 minutes), system components may malfunction. If the value is too large, the cluster management plane will be overloaded.
