Updated on 2025-11-11 GMT+08:00
Cluster Feature Gates
It controls whether to enable the kube-apiserver feature gates for a cluster. If this function is enabled, the system stores the resource field management information in metadata.managedFields to record the subject, time, and fields of historical operations.
Value Range
Feature gates supported by kube-apiserver. If multiple feature gates are used, separate them with commas (,).
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Do not change the value in the production environment without verification.
