Cluster Description
It specifies the description of a cluster. Configure the parameter as required. By default, it is left blank. To modify the description of a cluster after it is created, call the API that is used to update information about the cluster or go to the cluster details page on the CCE console.
Value Range
UTF-8 code only. Enter 1 to 200 characters.
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
