Updated on 2025-11-11 GMT+08:00
Default Scheduler
It specifies the cluster scheduler. Configure an appropriate scheduler for your clusters.
  • If it is set to kube-scheduler, the default Kubernetes scheduler will be used.
  • If it is set to Volcano, the enhanced Volcano scheduler will be used. Install the volcano add-on first.
Value Range
  • kube-scheduler: default Kubernetes scheduler
  • Volcano: enhanced scheduler
Default Value
kube-scheduler
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Set the parameter to kube-scheduler.
