Number of DaemonSet Objects That Are Allowed to Sync Concurrently
It specifies the number of DaemonSet objects that can be synchronized concurrently. A larger value indicates a quicker response and higher CPU (and network) load.
Value Range
Greater than or equal to 1
Default Value
2
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Unless otherwise specified, keep the default settings.
If this parameter is set to a small value, the manager may respond slowly. If it is set to a large value, the cluster control plane may be overloaded.
