Updated on 2025-11-11 GMT+08:00
Billing Mode
CCE supports the following billing modes:
  • Yearly/Monthly: a prepaid billing mode, where you pay in advance for a subscription term and receive a discounted rate. This mode is ideal when the resource use duration is predictable.
  • Pay-per-use: a postpaid billing mode, suitable for scenarios where resources are billed based on usage frequency and duration. You can provision or delete resources at any time.
A pay-per-use cluster can be changed to a yearly/monthly cluster, but a yearly/monthly cluster cannot be changed to a pay-per-use one.
When changing the billing mode of a cluster to yearly/monthly, you can also change the billing mode of the worker nodes in the cluster to yearly/monthly. The configuration takes effect only after the order is paid. Perform the operations following instructions.
Value Range
  • Pay-per-use
  • Yearly/Monthly
Default Value
Pay-per-use
Modifiable
Yes, but only a pay-per-use cluster can be changed to a yearly/monthly cluster.
Scope
CCE standard and Turbo clusters
Suggestions
Configure the yearly/monthly billing mode for clusters that will be used for a long time to reduce costs.
