Updated on 2025-11-11 GMT+08:00
Node Affinity
It specifies the node affinity policy configured for the volcano add-on.
  • If it is set to Not configured, node affinity is disabled for the add-on pods.
  • If it is set to Node Affinity, a node where the add-on pods will be deployed is specified. If you do not specify the node pool, the add-on will be randomly scheduled based on the default cluster scheduling policy.
  • If it is set to Specified Node Pool Scheduling, a node pool where the add-on pods will be deployed is specified. If you do not specify the node pool, the add-on will be randomly scheduled based on the default cluster scheduling policy.
  • If it is set to Custom Policies, you can take advantage of more flexible scheduling. You can enter labels of the nodes where the add-on is to be deployed. If you do not specify node labels, the add-on will be randomly scheduled based on the default cluster scheduling policy.
Value Range
Not configured, Node Affinity, Specified Node Pool Scheduling, or Custom Policies
Default Value
Not configured
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Keep the default settings.
