VPC
It specifies the Virtual Private Cloud (VPC) used by master nodes and worker nodes in a cluster.
Obtain the value using either of the following methods:
- Method 1: Log in to the VPC console and view the VPC ID in the VPC details page.
- Method 2: Use the VPC API.
Value Range
VPC IDs of the tenant
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
Suggestions
A VPC selected during cluster creation cannot be modified after the cluster is created. Select a proper VPC based on factors such as whether the IP addresses in the VPC are sufficient and whether the VPC is to be shared with other clusters and non-containerized applications.
