Master Node Subnet
It specifies the subnet used by the master nodes in a cluster.
It indicates the network ID of the subnet used to create a master node. Obtain the value using either of the following methods:
- Method 1: Log in to the VPC console and click the name of the target subnet on the Subnets page. You can view the network ID on the displayed page.
- Method 2: Use the VPC API.
Value Range
None
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
