Updated on 2025-06-13 GMT+08:00
Default Node Security Group
It specifies the default worker node security group ID in a cluster. If specified, the cluster will be bound to the target security group. Otherwise, the system will automatically create a default node security group. To ensure proper communication, allow traffic from certain ports to the default node security group.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
