ID List of the IPv4 Subnet That the Container ENIs Belong To
It specifies the ID list of the IPv4 subnet to which the container ENIs belong and is available only for CCE Turbo clusters. Multiple subnets can be configured for container ENIs.
Value Range
Subnet ID list. At most 20 subnet IDs are supported.
Default Value
None
Modifiable
Yes
Scope
CCE Turbo clusters
