List of Container CIDR Block
It specifies the list of container CIDR blocks in a cluster. In clusters 1.21 or later, the cidrs field is supported. If the cluster network type is vpc-router, multiple container CIDR blocks are supported. In clusters earlier than 1.21, if the cidrs field is used, the first CIDR element in the array will be used as the container CIDR block.
Value Range
List of container CIDR blocks. A maximum of 20 container CIDR blocks are supported.
Default Value
None
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
