Help Center/
Cloud Container Engine/
Drawer/
Configuration Reference/
Cluster/
Authentication/
Certificate Authentication
Updated on 2025-06-13 GMT+08:00
It specifies the cluster authentication mode.
- Kubernetes 1.11 or earlier supports x509, rbac, and authenticating_proxy. The default value is x509.
- Kubernetes 1.13 or later supports rbac and authenticating_proxy. The default value is rbac.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
