Updated on 2026-04-07 GMT+08:00
Elastic Bandwidth
If the actual bandwidth used by a service exceeds the service bandwidth, rate limiting and packet loss may occur. Elastic bandwidth can effectively prevent rate limiting and packet loss. Elastic bandwidth is the maximum available bandwidth (postpaid) for service traffic.
The elastic bandwidth of AAD is a post-paid, value-added item. Total available bandwidth = Service bandwidth + Elastic bandwidth
Billing Rules
The elastic bandwidth of AAD supports monthly 95th percentile billing. It can be scaled to up to 10,000 Mbit/s.
If your actual bandwidth exceeds the service bandwidth plus the elastic bandwidth, rate limiting and packet loss may occur. Select an elastic bandwidth based on your traffic volume.
The elastic bandwidth fees in different scenarios are described as follows.
Table 1 Billing rules
Service Bandwidth
Elastic Bandwidth
Actual Service Bandwidth
Elastic Bandwidth Fee
100 Mbit/s
Disabled
120 Mbit/s
No elastic bandwidth fees will be generated.
If bandwidth exceeds your configured quota, traffic may be limited and packet loss may occur.
100 Mbit/s
Enabled
100 Mbit/s
If the actual service bandwidth is less than or equal to the service bandwidth, no elastic service bandwidth fee is generated.
100 Mbit/s
Enabled
120 Mbit/s
Elastic bandwidth fees will be generated.
If the actual bandwidth is higher than the service bandwidth, elastic service bandwidth fees will be generated.
