Number of Forwarding Rules
The number of forwarding rules is the number of TCP/UDP forwarding rules that can be added to the AAD instance. This parameter is available only when the access type is IP access. By default, 50 forwarding rules can be added. You can pay for more. A maximum of 500 forwarding rules are supported.
