FAQs About ECSs
- How Do I Determine the Number of ECSs Required?
You can summarize the compute resources (such as CPUs and memory) occupied by your application software and estimate the number of required ECSs based on the compute resources provided by each ECS.
 - Can I Exclusively Use the Resources of ECSs?
Yes.
The compute resources provided on the public cloud are exclusive for your own use. And the resource will not be shared with other users.
 - Can ECSs in a Shared Resource Pool Be Added to a DCC?
No.
 - Can I Use the Hard Disks on Physical Servers as My Storage Resources?
No. You can only use the compute resources provided by physical servers. Specifically, the hard disks on the servers cannot be used as your storage resources.
