Experience Summary of Flink Performance Issues
Avoiding Data Skew
If data skew occurs (certain data volume is extremely large), the execution time of tasks is inconsistent even though no GC is performed.
- Redefine keys. Use keys of smaller granularity to optimize the task size.
 - Modify the DOP.
 - Call the rebalance operation to balance data partitions.
Setting Timeout Interval for the Buffer
- During the execution of tasks, data is exchanged through network. You can set the setBufferTimeout parameter to specify a buffer timeout interval for data exchanging among different servers.
 - If setBufferTimeout is set to -1, the refreshing operation is performed when the buffer is full to maximize the throughput. If setBufferTimeout is set to 0, the refreshing operation is performed each time data is received to minimize the delay. If setBufferTimeout is set to a value greater than 0, the refreshing operation is performed after the buffer times out.
    The following is an example:
env.setBufferTimeout(timeoutMillis); env.generateSequence(1,10).map(new MyMapper()).setBufferTimeout(timeoutMillis);
Reserving Resources
Reserve certain Yarn resources in the cluster for other tasks. For example, assume that there are 100 vCPU cores and 200 GB memory. Take 90 vCPU cores and 180 GB, and reserve about 10% of the total resources for automatic task retry and recovery in case of node faults.
