Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Impala/ Impala FAQ/ What Should I Do If the Impalad Session Connection Remains Inactive for a Long Time yet the Connection Does Not Get Disconnected Automatically?
Updated on 2025-07-16 GMT+08:00
Question
After JDBC is used to connect to Impala for query, the Impalad session connection is not automatically disconnected even if no query request is submitted for a long time.
Answer
To permanently apply the configuration, log in to FusionInsight Manager, choose Cluster > Services > Impala, and click Configurations, and then click All Configurations. In the tab, choose Impalad(Role) > Customization. Add parameter --idle_session_timeout to impalad.customized.configs, and set its value based on your actual business needs, with the unit being seconds. Save the configuration and restart the instance whose configuration expired.
