Table of Audit Logs
Updated on 2024-12-13 GMT+08:00
This function enables direct SQL statement execution for viewing and analyzing audit logs, eliminating the need to manually collect and analyze FE audit log files to check service volume and types. You can periodically import FE audit logs into a specified Doris table using Stream Load. The audit log table function is disabled by default. You can use the enable_audit_log_table parameter to enable this function.
This function is available only for MRS 3.5.0 and later versions.
  • Currently, the audit log table does not record operations such as Broker Load, Export, and Stream Load. You need to view the operations in the audit log.
  • To record the Stream Load operation with the audit log table, set the BE parameter enable_stream_load_record to true.
  • The audit log table records only information about SQL statements that have been executed.
  • By default, the maximum interval for writing data to the audit log table is 60 seconds, and the maximum amount of data that can be written in each batch is 50 MB. You can adjust the interval and amount by setting the max_batch_interval_sec and max_batch_size parameters.
Enabling Audit Log Table
  1. Log in to FusionInsight Manager, choose Cluster > Services > Doris > Configurations > All Configurations > FE(Role) > Log, and change the value of enable_audit_log_table to true.
  2. Click Save, and then click OK to save the configurations.
  3. Click Instances, select the affected FE instances, choose More > Restart Instance. Enter the password of the user and click OK to apply the configurations.
  4. After the MySQL client is connected to Doris (for details, see Getting Started with Doris), run the following command to view the SQL statements that have been executed by Doris:
    select * from __internal_schema.doris_audit_log_tbl__ limit 1;
    Figure 1 SQL statements that have been executed
    For details about each field, see Table 1.
Fields in the Audit Log Table
Table 1 Audit log table fields
Field
Type
query_id
varchar(48)
Query task ID.
time
datetime
Query start time.
client_ip
varchar(200)
IP address and port of the client.
user
varchar(64)
Name of the user who performs the query.
catalog
varchar(128)
Name of the catalog to which the query belongs.
db
varchar(96)
Name of the database to which the query belongs.
state
varchar(8)
Status of the query result.
error_code
int
Error code if the query fails
error_message
string
Error message if the query fails
query_time
bigint
Query execution time, in ms.
scan_bytes
bigint
Total number of bytes scanned by the query.
scan_rows
bigint
Total number of rows scanned by the query.
return_rows
bigint
Number of rows returned in the query result.
stmt_id
int
Serially numbered statement ID.
is_query
tinyint
Whether the statement is a query statement.
  • 1: indicates a query statement.
  • 0: indicates a non-query statement.
frontend_ip
varchar(200)
IP address of the FE that executes the query.
cpu_time_ms
bigint
Total CPU time of the query.
sql_hash
varchar(48)
Hash value of the query.
sql_digest
varchar(48)
SQL summary. The value is empty for non-slow queries.
peak_memory_bytes
bigint
Peak memory usage of all BE nodes, in bytes.
stmt
string
Information about the SQL statement that is executed.
reserve1
string
Reserved field 1
reserve2
string
Reserved field 2
