Configuring YARN Big Job Scanning
YARN's big job scanning function monitors local temporary files (such as shuffle files) and key HDFS directories (OBS is not supported) for Hive, HetuEngine, and Spark jobs. It reports events when jobs consume excessive storage resources (local disks or key HDFS directories).
For details about the monitored HDFS directories, see Table 1.
Notes and Constraints
This section applies only to MRS 3.5.0 and later versions.
For details about how to log in to FusionInsight Manager, see Accessing MRS FusionInsight Manager.
 - Choose Cluster > Services > Yarn > Configurations > All Configurations.
 - Search for following parameters and modify them as required.
- Configuring YARN big job monitoring
Table 2 Parameters for configuring YARN big job monitoring Parameter
Example Value
job.monitor.check.period
Interval for monitoring big jobs.
- The value 0 indicates that big job monitoring is disabled.
 - Value range: 1 to 720
 - Unit: minute
10
job.monitor.local.thread.pool
Number of threads for obtaining information about big jobs monitored by NodeManager.
Value range: 1 to 500
50
max.job.count
Number of big jobs displayed in the reported event.
5
job.monitor.local.dir.threshold
Threshold of the size of the job directory on NodeManager's local disk. An event will be triggered once this threshold is reached.
- Default value: 20
 - Value range: 1 to 1800000000000
 - Unit: GB
20
 - Configuring HetuEngine large job directory monitoring
Table 3 Parameters for configuring HetuEngine big job monitoring Parameter
Example Value
hetu.job.hdfs.monitor.dir
Big directory monitoring path of HetuEngine jobs. The root directory cannot be monitored.
If the directories to be monitored include variable directories such as user directories, replace them with /*/.
hdfs://hacluster/hetuserverhistory/*/coordinator/
hetu.job.appId.parser.rule
Rule for extracting job IDs in the big directory monitoring path of HetuEngine jobs. For example:
- {subdir}/{appid}: The job ID is in the subdirectory of the monitoring directory. The subdirectory name is not fixed.
 - {appid}: The job ID is in the monitoring directory.
{appid}
hetu.job.hdfs.dir.threshold
Big directory threshold of HetuEngine jobs. If the threshold is exceeded, an event is reported.
 - Default value: 100
 - Unit: GB
100
- Configuring Hive large job directory monitoring
- To activate the Hive component configuration in the big job scanning feature, set hive-ext.record.mr.applicationid to true. Here are the steps you need to take:
On FusionInsight Manager, choose Cluster > Services > Hive. Click Configurations then All Configurations. In the navigation pane on the left, choose HiveServer(Role) > Customization. Add hive-ext.record.mr.applicationid to hive.server.customized.configs set its value to true, and save the configuration.
On the All Configurations page of the YARN, modify the following parameters.
 - Currently, the Hive big job scanning feature applies only to the MapReduce engine.
Table 4 Parameters for configuring Hive big job monitoring Parameter
Example Value
hive.job.hdfs.monitor.dir
Big directory monitoring path of Hive jobs. The root directory cannot be monitored.
hdfs://hacluster/tmp/hive-scratch/*/
hive.job.appId.parser.rule
Rule for extracting job IDs in the big directory monitoring path of Hive jobs. For example:
{subdir}/{appid}
hive.job.hdfs.dir.threshold
Big directory threshold of monitored Hive jobs. If the threshold is exceeded, an event is reported.
 - Default value: 400
 - Unit: GB
400
 - Configuring Spark large job directory monitoring
Table 5 Parameters for configuring Spark big job monitoring Parameter
Example Value
spark.job.hdfs.monitor.dir
Big directory monitoring path of Spark jobs. The root directory cannot be monitored.
hdfs://hacluster/sparkJobHistory/
spark.job.appId.parser.rule
Rule for extracting the job ID in the large directory monitoring path of the monitored Spark job. For example:
{appid}
spark.job.hdfs.dir.threshold
Big directory threshold for monitoring Spark jobs. If the threshold is exceeded, an event is reported.
 - Unit: GB
100
 - Save the modified configuration. Restart the expired service or instance for the configuration to take effect.
