Updated on 2025-08-22 GMT+08:00
Hive Troubleshooting
This section describes common Hive faults and troubleshooting methods.
- Hive Log Types and Fault Locating
 - Hive Service Exceptions
- Failed to Start Hive
 - What Can I Do If the Hive Service Is Faulty?
 - Difference Between Hive Service Health Status and Hive Instance Health Status
 - Hive Service Status Is Unknown
 - Health Status of a HiveServer or MetaStore Instance Is unknown
 - Health Status of a HiveServer or MetaStore Instance Is Concerning
 - WebHCat Fails to Be Started After the Hostname Is Changed
 - Hive MetaStore Exception Occurs When the Number of DBService Connections Exceeds the Upper Limit
 - HiveServer and HiveHCat Process Faults
 - Failed to Restart Hive
 - WebHCat Failed to Start Due to Abnormal Health Status
 - WebHCat Failed to Start Because the mapred-default.xml File Cannot Be Parsed
 - Hive Client Task Running Exceptions
- Error Message "Cannot modify xxx at runtime" Is Displayed When the set Command Is Executed in a Security Cluster
 - Specifying a Queue When Submitting a Hive Task
 - Setting the Map/Reduce Memory on the Client
 - Specifying the Output File Compression Format When Importing a Hive Table
 - Description of the Hive Table Is Too Long to Be Completely Displayed
 - NULL Is Displayed When Data Is Inserted After the Partition Column Is Added to a Hive Table
 - Failed to Access ZooKeeper from the Client
 - "Invalid function" Is Displayed When a UDF Is Used
 - Garbled Characters Returned Upon a Query If Text Files Are Compressed Using ARC4
 - Hive Task Failed to Run on the Client but Successful on Yarn
 - Error Message "Execution Error return code 2" Is Displayed When the SELECT Statement Is Executed
 - Failed to Perform drop partition When There Are a Large Number of Partitions
 - Failed to Start the Local Task When the Join Operation Is Performed
 - Error Message "Failed to execute session hooks: over max connections" Is Displayed on the Beeline Client
 - Error Message "OutOfMemoryError" Is Displayed on the Beeline Client
 - Task Execution Fails Because the Input File Number Exceeds the Threshold
 - Hive Task Execution Fails Because of Stack Memory Overflow
 - Task Failed Due to Concurrent Writes to One Table or Partition
 - Failed to Load Data to Hive Tables
 - An Error Is Reported When Hive Executes the insert into Statement
 - Timeout Reported When Adding the Hive Table Field
 - Failed to Delete a Table Due to Excessive Hive Partitions
 - An Error Is Reported When msck repair table Is Executed on Hive
 - Releasing Disk Space After Dropping a Table in Hive
 - Abnormal Hive Query Due to Damaged Data in the JSON Table
 - Connection Timed Out During SQL Statement Execution on the Hive Client
 - An SQL Error Is Reported When the Number of MetaStore Dynamic Partitions Exceeds the Threshold
 - Hive User Permission Issues
- New User Created in the Cluster Does Not Have the Permission to Query Hive Data
 - An Error Is Reported When SQL Is Executed to Submit a Task to a Specified Queue
 - An Error Is Reported When the "load data inpath" Command Is Executed
 - An Error Is Reported When the "load data local inpath" Command Is Executed
 - An Error Is Reported When the create external table Command Is Executed
 - An Error Is Reported When the dfs -put Command Is Executed on the Beeline Client
 - Insufficient Permissions to Execute the set role admin Command
 - An Error Is Reported When a UDF Is Created on the Beeline Client
 - "authentication failed" Is Displayed During an Attempt to Connect to the Shell Client
 - Hive Task Failed Due to a Lack of HDFS Directory Permission
 - Insufficient User Permission for Running the insert into Command on Hive
 - Hive Sample Program Running Failures
   Parent topic: Using Hive
