Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using HetuEngine/
        Common HetuEngine SQL Syntax/
        HetuEngine Auxiliary Command Syntax/
      RESET SESSION
        Updated on 2024-12-13 GMT+08:00
RESET SESSION
Syntax
- RESET SESSION name
 - RESET SESSION catalog.name
This statement is used to reset the specified properties of the current session.
Example
RESET SESSION optimize_hash_generation; RESET SESSION hive.optimized_reader_enabled;
   Parent topic: HetuEngine Auxiliary Command Syntax
