On this page
Binary Functions and Operators
Updated on 2024-12-13 GMT+08:00
Binary Operators
|| The operator performs the join.
Binary Functions
  • length(binary) → bigint
    Return the byte length of binary.
    select length(x'00141f');-- 3
  • concat(binary1, ..., binaryN) → varbinary
    Concatenates binary1, binary2, and binaryN. This function returns the same function as the SQL standard connector ||.
    select concat(X'32335F',x'00141f'); -- 32 33 5f 00 14 1f
  • to_base64(binary) → varchar
    Encodes binary to a Base64 character string.
    select to_base64(CAST('hello world' as binary)); -- aGVsbG8gd29ybGQ=
  • from_base64(string) → varbinary
    Decode the Base64-encoded string as varbinary.
    select from_base64('helloworld'); --  85 e9 65 a3 0a 2b 95
  • unbase64(string) → varbinary
    SELECT from_base64('helloworld'); --  85 e9 65 a3 0a 2b 95
  • to_base64url(binary) → varchar
    Use URL security characters to encode binary to a base64 character string.
    select to_base64url(x'555555');  -- VVVV
  • from_base64url(string) → varbinary
    Use the URL security character to decode the Base64-encoded string into binary data.
    select from_base64url('helloworld'); --  85 e9 65 a3 0a 2b 95
  • to_hex(binary) → varchar
    Encode the binary to a hexadecimal string.
    select to_hex(x'15245F');  --  15245F
  • from_hex(string) → varbinary
    Decodes a hexadecimal string into binary data.
    select from_hex('FFFF'); --  ff ff
  • to_big_endian_64(bigint) → varbinary
    Encodes a number of the bigint type into a 64-bit big-endian complement.
    select to_big_endian_64(1234);
              _col0
     00 00 00 00 00 00 04 d2
    (1 row)
  • from_big_endian_64(binary) → bigint
    The binary code in 64-bit big-endian complement format is decoded as a number of the bigint type.
    select from_big_endian_64(x'00 00 00 00 00 00 04 d2');
     _col0
      1234
    (1 row)
  • to_big_endian_32(integer) → varbinary
    Encodes a number of the bigint type into a 32-bit big-endian complement.
    select to_big_endian_32(1999);
        _col0
     00 00 07 cf
    (1 row)
  • from_big_endian_32(binary) → integer
    The 32-bit big-endian two's complement format is decoded into a number of the bigint type.
    select from_big_endian_32(x'00 00 07 cf');
     _col0
      1999
    (1 row)
  • to_ieee754_32(real) → varbinary
    According to the IEEE 754 algorithm, a single-precision floating-point number is encoded into a 32-bit big-endian binary block.
    select to_ieee754_32(3.14);
        _col0
     40 48 f5 c3
    (1 row)
  • from_ieee754_32(binary) → real
    Decodes the 32-bit big-endian binary in IEEE 754 single-precision floating-point format.
    select from_ieee754_32(x'40 48 f5 c3');
     _col0
      3.14
    (1 row)
  • to_ieee754_64(double) → varbinary
    According to the IEEE 754 algorithm, a double-precision floating point number is encoded into a 64-bit big-endian binary block.
    select to_ieee754_64(3.14);
     _col0
     40 09 1e b8 51 eb 85 1f
    (1 row)
  • from_ieee754_64(binary) → double
    Decodes 64-bit big-endian binary in IEEE 754 single-precision floating-point format.
     select from_ieee754_64(X'40 09 1e b8 51 eb 85 1f');
     _col0
      3.14
    (1 row)
  • lpad(binary, size, padbinary) → varbinary
    Left-padded binary to adjust byte size using padbinary. If size is less than the length of the binary file, the result will be truncated to size characters. The value of size cannot be negative, and the value of padbinary cannot be empty.
    select lpad(x'15245F', 11,x'15487F') ; -- 15 48 7f 15 48 7f 15 48 15 24 5f
  • rpad(binary, size, padbinary) → varbinary
    Right-padded binary to use padbinary to resize bytes. If size is less than the length of the binary file, the result will be truncated to size characters. The value of size cannot be negative, and the value of padbinary cannot be empty.
    SELECT rpad(x'15245F', 11,x'15487F'); -- 15 24 5f 15 48 7f 15 48 7f 15 48
  • crc32(binary) → bigint
    Calculate the CRC 32 value of the binary block.
  • md5(binary) → varbinary
    Calculates the MD 5 hash value of a binary block.
  • sha1(binary) → varbinary
    Calculates the SHA 1 hash value of a binary block.
  • sha2(string, integer) → string
    SHA2 is a standard cryptographic hash algorithm used to convert a variable-length string into a string. Its output can be 224 bits, 256 bits, 384 bits, or 512 bits, corresponding to SHA-224, SHA-256, SHA-384 and SHA512, respectively.
  • sha256(binary) → varbinary
    Calculates the SHA 256 hash value of a binary block.
  • sha512(binary) → varbinary
    Calculates the SHA 512 hash value of a binary block.
  • xxhash64(binary) → varbinary
    Calculates the XXHASH 64 hash value of a binary block.
  • spooky_hash_v2_32(binary) → varbinary
    Calculates the 32-bit SpookyHashV2 hash value of a binary block.
  • spooky_hash_v2_64(binary) → varbinary
    Calculates the 64-bit SpookyHashV2 hash value of a binary block.
  • hmac_md5(binary, key) → varbinary
    Use the given key to calculate the HMAC value of the binary block (using MD5).
  • hmac_sha1(binary, key) → varbinary
    Use the given key to calculate the HMAC value of the binary block (using SHA1).
  • hmac_sha256(binary, key) → varbinary
    Use the given key to calculate the HMAC value of the binary block (using SHA256).
  • hmac_sha512(binary, key) → varbinary
    Use the given key to calculate the HMAC value of the binary block (using SHA512).
    NOTICE:
    The CRC32, MD5, and SHA1 algorithms have been found to have vulnerabilities. Do not use them for cryptography.
