On this page
Condition Expression
Updated on 2024-12-13 GMT+08:00
CASE
Standard SQL CASE expressions have two modes.
  • In simple mode, search for each value of the expression from left to right until the same expression is found.
    CASE expression
    WHEN value THEN result
    [ WHEN ... ]
    [ ELSE result ]
    END
    Returns the result that matches the value. If no value is matched, the result of the ELSE clause is returned. If there is no ELSE clause, null is returned. Example:
    select a,
    case a
     when 1 then 'one'
     when 2 then 'two'
     else 'many' end from
     (values (1),(2),(3),(4)) as t(a);
     a | _col1
     1 | one
     2 | two
     3 | many
     4 | many
    (4 rows)
  • In search mode, the system checks the Boolean value of each condition from left to right until the value is true and returns the matching result.
    CASE
    WHEN condition THEN result
    [ WHEN ... ]
    [ ELSE result ] END
    If none of the conditions is met, the result of the ELSE clause is returned. If there is no ELSE clause, null is returned. Example:
    select a,b,
    case
    when a=1 then 'one'
    when b=2 then 'tow'
    else 'many' end from (values (1,2),(3,4),(1,3),(4,2)) as t(a,b);
     a | b | _col2
     1 | 2 | one
     3 | 4 | many
     1 | 3 | one
     4 | 2 | tow
    (4 rows)
IF
The IF function is a language structure. It has the same function as the following CASE expression:
CASE
WHEN condition THEN true_value
[ ELSE false_value ] END
  • if(condition, true_value)
    If condition is true, true_value is returned. Otherwise, null is returned and true_value is not calculated.
    select if(a=1,8) from (values (1),(1),(2)) as t(a); -- 8 8 NULL
    select if(a=1,'value') from (values (1),(1),(2)) as t(a); -- value value NULL
  • if(condition, true_value, false_value)
    If condition is true, true_value is returned. Otherwise, false_value is returned.
    select if(a=1,'on','off') from (values (1),(1),(2)) as t(a);
    _col0
     on
     on
     off
    (3 rows)
COALESCE
coalesce(value[, ...])
Returns the first non-null value in the parameter list. Similar to CASE expressions, parameters are calculated only when necessary.
It is similar to the nvl function of MySQL and is often used to convert a null value to 0 or ' ' (null character).
 select coalesce(a,0) from (values (2),(3),(null)) as t(a); -- 2 3 0
NULLIF
  • nullif(value1, value2)
    If value1 is equal to value2, null is returned. Otherwise, value1 is returned.
    select nullif(a,b) from (values (1,1),(1,2)) as t(a,b); --
     _col0
      NULL
    (2 rows)
  • ZEROIFNULL(value)
    If the value is null, 0 is returned. Otherwise, the original value is returned. Currently, the varchar type is also supported.
    select zeroifnull(a),zeroifnull(b),zeroifnull(c) from (values (null,13.11,bigint '157'),(88,null,bigint '188'),(55,14.11,null)) as t(a,b,c);
     _col0 | _col1 | _col2
         0 | 13.11 |   157
        88 |  0.00 |   188
        55 | 14.11 |     0
    (3 rows)
  • NVL(value1,value2)
    If value1 is null, value2 is returned. Otherwise, value1 is returned.
    select nvl(NULL,3);  -- 3
    select nvl(2,3);    --2
  • ISNULL(value)
    If value1 is null, true is returned. Otherwise, false is returned.
    Create table nulltest(col1 int,col2 int);
    insert into nulltest values(null,3);
    select isnull(col1),isnull(col2) from nulltest;
     _col0 | _col1
     true  | false
    (1 row)
  • ISNOTNULL(value)
    If value1 is null, false is returned. Otherwise, true is returned.
    select isnotnull(col1),isnotnull(col2) from nulltest;
     _col0 | _col1
     false | true
    (1 row)
TRY
Evaluates an expression. If an error occurs, Null is returned. It is similar to try catch in the programming language. The TRY function is generally used together with COALESCE. COALESCE can convert an abnormal null value to 0 or null. The following situations will be captured by the TRY function:
  • The denominator is 0.
  • The cast operation or function input parameter is incorrect.
  • The number exceeds the defined length.
This method is not recommended. Specify the preceding exceptions and preprocess data.
Example:
Assume that the origin_zip field in the following table contains invalid data:
--Create a table.
create  table shipping (origin_state varchar,origin_zip varchar,packages int ,total_cost int);
--Insert data.
insert into shipping
values
('California','94131',25,100),
('California','P332a',5,72),
('California','94025',0,155),
('New Jersey','08544',225,490);
--Query data.
SELECT * FROM shipping;
 origin_state | origin_zip | packages | total_cost
 California   |      94131 |       25 |        100
 California   |      P332a |        5 |         72
 California   |      94025 |        0 |        155
 New Jersey   |      08544 |      225 |        490
(4 rows)
The query fails when TRY is not used:
SELECT CAST(origin_zip AS BIGINT) FROM shipping;
Query failed: Cannot cast 'P332a' to BIGINT
When TRY is used, null is returned:
SELECT TRY(CAST(origin_zip AS BIGINT)) FROM shipping;
 origin_zip
     94131
     NULL
     94025
     08544
 (4 rows)
SELECT total_cost/packages AS per_package FROM shipping;
Query failed: Division by zero
The default values are returned when TRY and COALESCE are used.
SELECT COALESCE(TRY(total_cost/packages),0) AS per_package FROM shipping;
 per_package
    4
    14
    0
    19
 (4 rows)
