START TRANSACTION
Syntax
START TRANSACTION [ mode [, ...] ]
mode is used to set the transaction isolation level. The options are as follows:
ISOLATION LEVEL { READ UNCOMMITTED | READ COMMITTED | REPEATABLE READ | SERIALIZABLE }
READ { ONLY | WRITE }
This statement is used to start a new transaction in the current session.
Example
START TRANSACTION; START TRANSACTION ISOLATION LEVEL REPEATABLE READ; START TRANSACTION READ WRITE; START TRANSACTION ISOLATION LEVEL READ COMMITTED, READ ONLY; START TRANSACTION READ WRITE, ISOLATION LEVEL SERIALIZABLE;
Nested transactions are not supported. That is, after a transaction is started, other transactions cannot be started before the transaction is committed.
