SHOW TBLPROPERTIES TABLE|VIEW
Syntax
SHOW TBLPROPERTIES table_name|view_name[(property_name)]
View the properties of a table or the properties of a keyword.
If you do not specify an attribute keyword, this statement returns all table attributes.
Otherwise, this statement returns the attribute that matches the specified keyword.
Example
-- View all table attributes of show_table1.
SHOW TBLPROPERTIES
STATS_GENERATED_VIA_STATS_TASK 'workaround for potential lack of HIVE-12730'
auto.purge 'false'
numFiles '0'
numRows '0'
orc.compress.size '262144'
orc.compression.codec 'GZIP'
orc.row.index.stride '10000'
orc.stripe.size '67108864'
presto_query_id '20230909_095107_00042_2hwbg@default@HetuEngine'
presto_version '399'
rawDataSize '0'
totalSize '0'
transient_lastDdlTime '1694253067'
(1 row)
-- View the compression algorithm of show_table1.
SHOW TBLPROPERTIES show_table1('orc.compression.codec');
SHOW TBLPROPERTIES
GZIP
(1 row) What is your overall rating for this page?
