On this page
Column Permission Management
Updated on 2024-12-13 GMT+08:00
You can manage column-level permission in Doris by adding the enable_col_auth parameter to the custom configuration of the FE service.
  • This feature is available for MRS 3.3.1 or later only.
  • Only the Select_priv permission is supported by this function.
  • You must use a user with the Grant_priv permission to manage column permission.
  • If a user with the column-level Select_priv permission runs select * to query table data, it can access only the columns allowed by the permission.
  • If a user with the column-level Select_priv permission runs desc tbl to query table details, it can access only the information of columns allowed by the permission.
  • Column-level permission is also available for views and materialized views.
Prerequisite
  • A cluster containing the Doris service has been created, and all services in the cluster are running properly.
  • The nodes to be connected to the Doris database can communicate with the MRS cluster.
  • The MySQL client has been installed. For details, see Using the MySQL Client to Connect to Doris.
  1. Log in to FusionInsight Manager, choose Cluster > Services > Doris, and click Configurations and then All Configurations.
  2. Choose FE(Role) > Customization. Enter the custom parameter enable_col_auth, set its value to true, and add it to the fe.conf file.
  3. Click Save and then OK.
  4. Click Instances, select all FE instances, and choose More > Restart Instance.
  5. Log in to the node where MySQL is installed and run the following command to connect to the Doris database:
    If Kerberos authentication is enabled for the cluster (the cluster is in security mode), run the following command to connect to the Doris database:
    export LIBMYSQL_ENABLE_CLEARTEXT_PLUGIN=1
    mysql -uDatabase login user -p -PConnection port for FE queries -hIP address of the Doris FE instance
    Enter the password for logging in to the database.
    • To obtain the query connection port of the Doris FE instance, you can log in to FusionInsight Manager, choose Cluster > Services > Doris > Configurations, and query the value of query_port of the Doris service.
    • To obtain the IP address of the Doris FE instance, log in to FusionInsight Manager of the MRS cluster and choose Cluster > Services > Doris > Instances to view the service IP address of any FE instance.
    • You can also use the MySQL connection software or Doris web UI to connect to the database.
  6. Run the following commands to grant the Select_priv permission:
    • Grant permission to a user.
      GRANT select_priv [(col1, col2...)] ON ctl.db.tbl TO 'user';
    • Grant permission to a role.
      GRANT select_priv [(col1, col2...)] ON ctl.db.tbl TO ROLE 'role';
  7. Check the user permission.
    show grants for user;
  8. Revoke the Select_priv permission.
    • Revoke permission from a user.
      revoke select_priv [(col1, col2...)] ON ctl.db.tbl from 'user';
    • Revoke permission from a role.
      revoke select_priv [(col1, col2...)] ON ctl.db.tbl from ROLE 'role';
  9. Check user permission.
