Triggering TTL Events
Function
A TTL event is triggered based on the interval configured using ttl_configuration. However, you can trigger the TTL immediately.
Syntax
call ttl_policy_run(table => "[table]", path => "[path]", dryRun => [dryRun])
- If dryRun is true, aged partitions are detected based on the TTL policy configured in the Hudi table and only aged partitions are printed.
- If dryRun is true, aged partitions are detected based on the TTL policy configured in the Hudi table and only aged partitions are logically deleted. The logical deletion operation generates a replacecommit. When the cleaning operation is performed, the aged partitions are automatically and physically deleted.
Parameter Description
| Parameter | Description | Mandatory |
| table | Table name. Database name.Table name is also supported. The value is a string. | No. Specify either table or path. |
| path | Absolute path of the table. The value is a string. | No. Specify either table or path. |
| dryRun | The value is of the Boolean type. | No. The value can be false or true. The default value is false. |
Example
Manually trigger a TTL event:
call ttl_policy_run(table => "hudi_table", dryRun => false)
