Updated on 2026-06-27 GMT+08:00
Submitting a Job on the FlinkSQL Client
This section describes how to use FlinkSQL Client to submit jobs.
  • Flink has been installed in the MRS cluster and all components in the cluster are running properly.
  • The cluster client has been installed, for example, in /opt/hadoopclient.
  1. Log in to the node where the client is installed as the client installation user.
  2. Run the following command to go to the client installation directory:
    cd /opt/hadoopclient
  3. Run the following command to initialize environment variables:
    source /opt/hadoopclient/bigdata_env
  4. Log in to the FlinkSQL Client and submit a job.
    1. Start yarn-session by referring to Using the Flink Client and record yarn-session ID (yid).
      yarn-session.sh -nm "session-name"
    2. Run the following command to access the FlinkSQL Client:
      cd /opt/hadoopclient/Flink/flink/bin
      ./sql-client.sh
      Figure 1 Accessing the FlinkSQL Client
    3. Set high-availability.cluster-id to the yarn-session ID.
      SET high-availability.cluster-id=yarn-session ID;
    1. Run the following SQL statement. If the execution is successful, the following information is displayed on the console.
      SELECT name, COUNT(*) AS cnt FROM ( VALUES ('Bob'), ('Alice'), ('Greg'), ('Bob') ) AS NameTable(name) GROUP BY name;
      Figure 2 Execution result
    2. View the executed job on Yarn.
      Log in to FusionInsight Manager, choose Cluster > Services > Yarn > Dashboard, and click the link next to ResourceManager WebUI to go to the Yarn web UI and view the job.
      Figure 3 Job
