What Should I Do If the Data Volume of a Broker Load Import Task Exceeds the Threshold?
Symptom
The following error message was displayed when Broker Load was used to import data:
Scan bytes per broker scanner exceed limit:xxx
Cause Analysis
The maximum data volume of a single import task processed by the BE process is 3 GB. You can adjust the import parameters of Broker Load for large files.
Modify the maximum scan amount and maximum concurrent number of tasks of a single BE node according to the current number of BE instances and the size of the files to be imported. Perform the following steps to modify the parameters:
- Log in to FusionInsight Manager and choose Cluster > Services > Doris. On the dashboard page, view the IP address of leader host to determine the node where the active FE node is deployed.
 - Click Instance, and click the BE instance whose IP address was viewed in 1. Click Configurations > All Configurations, select BE (Role) > Customization, and add the following parameters:
- max_broker_concurrency: number of BE nodes
 - max_bytes_per_broker_scanner: size of the file to be imported/number of BE nodes
     The configuration items take effect only when they are modified in the fe.conf file of the leader FE.
 - Click Save to save the configuration and restart the instance whose configuration has expired.
