On this page
CREATE TABLE
This section describes the basic SQL syntax and usage of Doris for creating tables.
Basic Syntax
CREATE TABLE [IF NOT EXISTS] [database.]table
column_definition_list,
[index_definition_list]
[engine_type]
[keys_type]
[table_comment]
[partition_info]
distribution_desc
[rollup_list]
[properties]
[extra_properties]
Use Example
  • To create an ordinary table named table1, run the following command:
    CREATE TABLE example_db.table1
    k1 TINYINT,
    k2 DECIMAL(10, 2) DEFAULT "10.5",
    k3 CHAR(10) COMMENT "string column",
    k4 INT NOT NULL DEFAULT "1" COMMENT "int column"
    COMMENT "table comment"
    DISTRIBUTED BY HASH(k1) BUCKETS 32;
  • Create a partitioned table named table2.
    Use the event_day column as the partition column and create three partitions: p201706, p201707, and p201708. The values are as follows:
    • p201706: The value range is [Minimum value, 2017-07-01).
    • p201707: The value range is [2017-07-01, 2017-08-01).
    • p201708: The value range is [2017-08-01, 2017-09-01).
    Each partition uses siteid for hash bucketing. The number of buckets is 10.
    The command for creating a table is as follows:
    CREATE TABLE table2
    event_day DATE,
    siteid INT DEFAULT '10',
    citycode SMALLINT,
    username VARCHAR(32) DEFAULT '',
    pv BIGINT SUM DEFAULT '0'
    AGGREGATE KEY(event_day, siteid, citycode, username)
    PARTITION BY RANGE(event_day)
    PARTITION p201706 VALUES LESS THAN ('2017-07-01'),
    PARTITION p201707 VALUES LESS THAN ('2017-08-01'),
    PARTITION p201708 VALUES LESS THAN ('2017-09-01')
    DISTRIBUTED BY HASH(siteid) BUCKETS 10
    PROPERTIES("replication_num" = "1");
    • When Doris creates a table, at least two copies must be specified to ensure high availability.
    • You can add a rollup table to a table to improve query performance.
    • By default, the Null attribute of a column in a table is true, which affects the query performance.
    • The bucket column must be specified for the Doris table.
  • View the table content.
    • SHOW TABLES;
      | Tables_in_example_db |
      | table1               |
      | table2               |
      2 rows in set (0.01 sec)
    • DESC table1;
      | Field    | Type        | Null | Key   | Default | Extra |
      | siteid   | int(11)     | Yes  | true  | 10      |       |
      | citycode | smallint(6) | Yes  | true  | N/A     |       |
      | username | varchar(32) | Yes  | true  |         |       |
      | pv       | bigint(20)  | Yes  | false | 0       | SUM   |
      4 rows in set (0.00 sec)
    • DESC table2;
      | event_day | date        | Yes  | true  | N/A     |       |
      5 rows in set (0.00 sec)
