Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Doris/
        Typical SQL Syntax of Doris/
      CREATE DATABASE
CREATE DATABASE
This section describes the basic SQL syntax and usage of the Doris database.
Basic Syntax
CREATE DATABASE [IF NOT EXISTS] db_name
[PROPERTIES ("key"="value", ...)];
Use Example
- Connect to Doris through MySQL client as a user with Doris administrator permissions.
 - Run the following command to create the database example_db:
create database if not exists example_db;
 - Run the following command to view the database information:
SHOW DATABASES;
mysql> SHOW DATABASES; +--------------------+ | Database | +--------------------+ | example_db | | information_schema | +--------------------+ 2 rows in set (0.00 sec)
 - Run the following command to switch to example_db:
use example_db;
   Parent topic: Typical SQL Syntax of Doris
