On this page
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using CDL/ Creating a CDL Job/ Synchronizing drs-oracle-json Database to Hudi Using CDL (ThirdKafka)
Import Oracle database data from ThirdKafka to Hudi on the CDLService web UI of a cluster with Kerberos authentication enabled.
This section applies to MRS 3.3.0 or later.
  • The CDL and Hudi services have been installed in a cluster and are running properly.
  • Topics of the ThirdKafka database can be consumed by the MRS cluster. For details, see Prerequisites for ThirdPartyKafka.
  • You have created a human-machine user, for example, cdluser, added the user to user groups cdladmin (primary group), hadoop, kafka, and supergroup, and associated the user with the System_administrator role on FusionInsight Manager.
  1. Log in to FusionInsight Manager as user cdluser (change the password upon your first login), choose Cluster > Services > CDL, and click the link next to CDLService UI to go to the CDLService web UI.
  2. Choose Link Management and click Add Link. On the displayed dialog box, set parameters for adding the thirdparty-kafka and hudi links by referring to the following tables. Creating a CDL Database Connection describes the data link parameters.
    Table 1 thirdparty-kafka data link parameters
    Example Value
    Name
    oraclelink
    Link Type
    thirdparty-kafka
    Bootstrap Servers
    10.10.10.10:9093
    Security Protocol
    SASL_SSL
    Username
    testuser
    Password
    Password of the testuser user
    SSL Truststore Location
    Click Upload to upload the authentication file.
    SSL Truststore Password
    Datastore Type
    drs-oracle-json
    thirdparty-kafka Link
    MRS Kafka can also be used as the source of thirdparty-kafka. If the username and password are used for login authentication, log in to FusionInsight Manager, choose Cluster > Services > Kafka, click Configurations, search for the sasl.enabled.mechanisms parameter in the search box, add PLAIN as the parameter value, click Save to save the configuration, and restart the Kafka service for the configuration to take effect.
    On the CDL web UI, configure the thirdparty-kafka link that uses MRS Kafka as the source. For example, the data link configuration is as follows:
    Table 2 Hudi data link parameters
    Example Value
    Link Type
    hudi
    Name
    hudilink
    Storage Type
    hdfs
    Auth KeytabFile
    /opt/Bigdata/third_lib/CDL/user_libs/cdluser.keytab
    Principal
    cdluser
  3. After the parameters are configured, click Test to check whether the data link is normal.
    After the test is successful, click OK.
  4. (Optional) Choose ENV Management and click Add Env. In the displayed dialog box, configure the parameters based on the following table.
    Table 3 Parameters for adding an ENV
    Example Value
    Name
    test-env
    Driver Memory
    1 GB
    Type
    spark
    Executor Memory
    1 GB
    Executor Cores
    Number Executors
    Queue
    Click OK.
  5. Choose Job Management > Data synchronization task and click Add Job. In the displayed dialog box, set parameters. Click Next.
    Specifically:
    Example Value
    Name
    job_oracletohudi
    Desc
    New CDL Job
  6. Configure ThirdKafka job parameters.
    1. On the Job Management page, drag the thirdparty-kafka icon on the left to the editing area on the right and double-click the icon to go to the ThirdpartyKafka job configuration page. Set parameters by referring to the following table. Creating a CDL Data Synchronization Job describes the job parameters.
      Table 4 thirdparty-kafka job parameters
      Example Value
      Link
      oraclelink
      DB Name
      oracledb
      Schema
      oracleschema
      Datastore Type
      drs-oracle-json
      Source Topics
      source_topic
      Tasks Max
      Tolerance
      none
      Data Filter Time
      Topic Table Mapping
      test/hudi_topic
    2. Click OK. The ThirdpartyKafka job parameters are configured.
  7. Configure Hudi job parameters.
    1. On the Job Management page, drag the hudi icon in the Sink area on the left to the editing area on the right and double-click the icon to go to the Hudi job configuration page. Set parameters by referring to the following table. Creating a CDL Data Synchronization Job describes the job parameters.
      Table 5 Sink Hudi job parameters
      Example Value
      Link
      hudilink
      Path
      /cdl/test
      Interval
      10
      Max Rate Per Partition
      0
      Parallelism
      10
      Target Hive Database
      default
      Configuring Hudi Table Attributes
      Visual View
      Global Configuration of Hudi Table Attributes
      Configuring the Attributes of the Hudi Table: Table Name
      test
      Configuring the Attributes of the Hudi Table: Table Type Opt Key
      COPY_ON_WRITE
      Configuring the Attributes of the Hudi Table: Hudi TableName Mapping
      Configuring the Attributes of the Hudi Table: Hive TableName Mapping
      Configuring the Attributes of the Hudi Table: Table Primarykey Mapping
      id
      Configuring the Attributes of the Hudi Table: Table Hudi Partition Type
      Configuring the Attributes of the Hudi Table: Custom Config
    2. (Optional) Click the plus sign (+) to display the Execution Env parameter. Select a created environment for it. The default value is defaultEnv.
    3. Click OK.
  8. Drag the two icons to associate the job parameters and click Save. The job configuration is complete.
  9. In the job list on the Job Management page, locate the created job, click Start in the Operation column, and wait until the job is started.
    Check whether the data transmission takes effect, for example, insert data into the table in the Oracle database and view the content of the file imported to Hudi.
