On this page
Guardian Log Overview
Updated on 2024-12-13 GMT+08:00
Log Description
Log path: /var/log/Bigdata/guardian/token-server
Log archive rule: The automatic compression and archive function is enabled for Guardian run logs. When the total size of all log files exceeds 50 MB (configurable), the log files are automatically compressed into a package named in the format of token-server.log.[ID]. A maximum of 20 latest compressed files are retained. The number of compressed files and compression threshold can be configured.
Table 1 Guardian log list
Log Type
Log File Name
Searchable on Manager
Run log
token-server.log
Guardian run log
Yes
startDetail.log
Guardian service prestart log
Yes
stopDetail.log
Guardian service stop log
Yes
gc.log
Guardian service GC log
No
Log Levels
Table Table 2 describes the log levels provided by Guardian.
The log levels are ERROR, WARN, INFO, and DEBUG in descending order of priority. Only logs whose levels are higher than or equal to the specified level are recorded. The higher the log level specified, the fewer the logs are recorded.
Table 2 Log levels
Level
ERROR
Logs of this level record error information about system running
WARN
Logs of this level record exception information about the current event processing
INFO
Logs of this level record normal running status information about the system and events
DEBUG
Logs of this level record the system information and system debugging information
To modify log levels, perform the following operations:
  2. Choose Cluster > Services > Guardian. Click Configurations then All Configurations.
  3. On the menu bar on the left, select the log menu of the target role.
  4. Select a desired log level.
  5. Click Save then OK.
    The configurations take effect immediately without the need to restart the service.
Log Format
Table 3 describes the Guardian log format.
Table 3 Log format
Log Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Location where the log event occurs>|< Location of the log event >|<Message in the log>
2024-05-23 09:54:11,696 | INFO | pool-12-thread-1-EventThread:53211544 | mrs.guardian.shaded.org.apache.curator.framework.state.ConnectionStateManager: | ConnectionStateManager.java:252 |
State change: CONNECTED
