Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Flink/
      Enterprise-Class Enhancements of Flink
        Updated on 2025-08-22 GMT+08:00
- Flink SQL Syntax Enhancement
 - Table-Level TTL for Stream Joins
 - Configuring Flink SQL Client to Support SQL Verification
 - Enhancing the Joins of Large and Small Tables in Flink Jobs
 - Exiting FlinkSQL OVER Window Upon Expiration
 - Limiting Read Rate for Flink SQL Kafka and Upsert Kafka Connector
 - Consuming Data in drs-json Format with Flink SQL Kafka Connector
 - Using ignoreDelete in JDBC Data Writes by Flink SQL
 - Support for JTL by Flink SQL
 - Flink SQL Row-Level Filtering
 - Flink SQL Operator Parallelism
 - Optimizing Performance of the JSON_VALUE Function in Flink SQL
 - Reusing the Flink SQL Lookup Operator
 - Flink SQL Function Enhancements
 - Using the MultiJoin Operator in Flink SQL
   Parent topic: Using Flink
