Updated on 2026-08-29 GMT+08:00
Submitting a Spark Job as a Proxy User
Submit a Spark task as the actual running user or a proxy user. This section describes how to enable the proxy user function to submit Spark tasks.
Notes and Constraints
This section applies only to MRS 3.3.0-LTS and later.
The test (actual runtime user) and test1 (proxy user) users have been created and added to the hadoop (primary group), hive, and supergroup groups on MRS Manager.
The actual runtime user is the identity used by the server, while the proxy user represents the corresponding service user. When permission control is enabled, the authorization model for the proxy user is identical to that of a standard service user.
Submitting a Spark Task as a Proxy User in spark-beeline
  1. Modify JDBCServer instance parameters.
    Log in to FusionInsight Manager and choose Cluster > Services > Spark. Click Configurations and then All Configurations, choose JDBCServer(Role) > Customization, find the spark.core-site.customized.configs parameter, and add the following custom parameters:
    Value
    hadoop.proxyuser.test.hosts
    In the configuration, test is the actual user, which indicates that any proxy user can be used after user test is connected and the number of cluster nodes is not limited.
    hadoop.proxyuser.test.groups
  2. Change the values of the following parameters to switch to the JDBCServer multi-instance mode:
    Value
    spark.scheduler.allocation.file
    #{conf_dir}/fairscheduler.xml
    Path to the fair scheduler XML file that is shared among multiple tenants and instances.
    spark.thriftserver.proxy.enabled
    false
    Whether to use the multi-tenant mode. false indicates that the multi-instance mode is used. true indicates that the multi-tenant mode is used.
  3. Save the configuration and restart the Spark service.
  4. Log in to the Spark client node and run the following commands:
    Navigate to the directory where the client is installed.
    cd Client installation directory
    Load the environment variables.
    source bigdata_env
    Load the component environment variables.
    source Spark/component_env
    In security mode, additionally perform the security authentication. Authentication is not required in normal mode.
    kinit test
    Enter the password for authentication. (Change the password upon your first login.)
  5. Use Beeline commands of Spark to submit a task.
    Go to the Beeline directory of Spark.
    cd Client installation directory/Spark/spark/bin
    Enable the Beeline command.
    ./beeline
    Submit a task as a proxy user.
    !connect jdbc:hive2://IP address of the node where the ZooKeeper instance is deployed:ZooKeeper client port,IP address of the node where the ZooKeeper instance is deployed:ZooKeeper client port,IP address of the node where the ZooKeeper instance is deployed:ZooKeeper client port/;serviceDiscoveryMode=zooKeeper;zooKeeperNamespace=sparkthriftserver;saslQop=auth-conf;auth=KERBEROS;principal=spark2x/hadoop.hadoop.com@HADOOP.COM;hive.server2.proxy.user=test1
    Specifically:
    • IP address of the node where the ZooKeeper instance is: To obtain the IP address, on FusionInsight Manager, choose Cluster > Services > ZooKeeper and click Instance.
    • Port number of the ZooKeeper client: To obtain the port number, on FusionInsight Manager, choose Cluster > Services > ZooKeeper, click Configurations and then All Configurations, and search for clientPort.
    • hive.server2.proxy.user=test1: test1 is a proxy user.
  6. Create a Spark table.
    create table sparktest1(a string,b int);
    View the created table.
    desc formatted sparktest1;
    You can see that Owner of the table is the proxy user test1, and the proxy user is successfully used.
Submitting a Spark Task as a Proxy User in spark-sql and spark-submit
  1. Modify the HDFS instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > HDFS. Click Configurations and then All Configurations, click HDFS(Service), select Customization, find the hdfs.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  2. Modify the Yarn instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Yarn. Click Configurations then All Configurations, click Yarn(Service), select Customization, find the yarn.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  3. Modify the SparkResource instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Spark. Click Configurations and then All Configurations, click SparkResource(Role), select Customization, find the spark.core-site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  4. Modify the Hive instance configuration. Log in to FusionInsight Manager and choose Cluster > Services > Hive. Click Configurations and then All Configurations, click Hive(Service), select Customization, find the core.site.customized.configs parameter, add the following custom parameters, and save the configuration:
    Value
  5. Restart the HDFS, YARN, Spark, and Hive services and update the configuration files on their clients.
  6. Log in to the Spark client node and run the following commands:
    source bigdata_env
    kinit test
  7. Submit the spark-sql task.
    spark-sql --master yarn --proxy-user test1
  8. Create a Spark table.
    create table sparktest2(a string,b int);
    desc formatted sparktest2;
  9. Use the redelivered client to submit the spark-submit task.
    spark-submit --master yarn --class org.apache.spark.examples.SparkPi --master yarn-client --proxy-user test1 Client installation directory/Spark/spark/examples/jars/spark-examples_*.jar
  10. View information about applications running in YARN.
    You can see that the running user of the task is test1, and the proxy user is successfully used.
