On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using ClickHouse/ Common Issues About ClickHouse/ How Do I Grant the Select Permission at the Database Level to ClickHouse Users?
Updated on 2024-10-25 GMT+08:00
  1. Log in to the node where the ClickHouse client is installed in the MRS cluster and run the following commands:
    su - omm
    source {Client installation directory}/bigdata_env
    kinit Component user (You do not need to run the kinit command for normal clusters.)
    clickhouse client --host IP address of the ClickHouse node --port 9000 -m --user clickhouse –password 'Password of the ClickHouse user'
    • View the password of the ClickHouse user.
      Log in to FusionInsight Manager and choose Cluster > Services > ClickHouse. Click Instance and click any ClickHouseServer role name. Go to the Dashboard tab page of ClickHouseServer, click the users.xml file in Configuration File area, and view the password of the ClickHouse user.
    • Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
  2. You can use either of the following methods to create a role with the read-only permission for a specified database:
    Method 1
    1. Creating a role with the read-only permission for a specified database (the default database is used as an example)
      create role ck_role on cluster default_cluster;
      GRANT SELECT ON default.* TO ck_role on cluster default_cluster;
    2. Creating a common user
      CREATE USER user_01 on cluster default_cluster IDENTIFIED WITH PLAINTEXT_PASSWORD BY 'password';
    3. Granting the read-only permission role to a common user
      GRANT ck_role to user_01 on cluster default_cluster;
    4. Viewing user permissions
      show grants for user_01;
      select * from system.grants where role_name = 'ck_role';
    Method 2
    Creating a user with the read-only permission for a specified database
    1. Creating a user:
    1. Granting the query permission on a specified database to the created user:
      grant select on default.* to user_01 on cluster default_cluster;
    2. Querying user permissions:
      select * from system.grants where user_name = 'user_01';
