Interconnecting ClickHouse with OBS
Using S3 Table Functions
  1. Log in to the active OMS node.
  2. Run the following command to obtain the data stored in OBS:
    select * from S3(path, [ak, sk,] format, structure, [compression])
    • path: Access domain name/OBS file path. Log in to OBS console and choose Parallel File Systems. On the page that is displayed, click the file system name. On the Files tab page, click the file name. The value of Link is the path.
      Figure 1 File path
    • ak: Optional. The AK that has the permission to access OBS.
    • sk: Optional. The SK that has the permission to access OBS.
    • format: The file format.
    • structure: The table schema.
    • compression: Optional. The compression type.
Using the S3 Table Engine
  2. Run the following commands to create a table:
    CREATE TABLE test1_s3 ('name' String, 'age' int)
    ENGINE = S3(path, [ak, sk,] format, [compression])
  3. Run the following command to query the table:
    select * from test1_s3;
Modifying Manager Configurations
  1. Log in to FusionInsight Manager and choose Cluster > Services > ClickHouse. Click Configurations then All Configurations. Search for the clickhouse-config-customize parameter and add values. The following table lists the parameter values.
    Value
    s3.endpoint-name.endpoint
    OBS bucket address
    s3.endpoint-name.access_key_id
    OBS AK. For details on how to obtain the AK, see How Do I Obtain the Access Key AK/SK?
    s3.endpoint-name.secret_access_key
    OBS SK. For details about how to obtain the OBS SK, see How Do I Obtain the AK/SK?
  1. Typically, the URL shared by OBS contains HTTPS. If the URL is inaccessible directly, perform the following operations to modify the configuration:
    Value
    openSSL.client.loadDefaultCAFile
    true
    openSSL.client.cacheSessions
    true
    openSSL.client.disableProtocols
    sslv2,sslv3
    openSSL.client.preferServerCiphers
    true
    openSSL.client.invalidCertificateHandler.name
    AcceptCertificateHandler
  2. After the modification, click Save.
