Updated on 2025-07-16 GMT+08:00
Purging Historical Loader Data
This section applies to MRS 3.2.0 or later.
Loader accumulates a large amount of historical data during service running. The historical data may affect job submission, running, and status query, and even cause page freezing and job running failures. Therefore, you need to properly configure the historical data purge policy based on the Loader service data volume.
  2. Choose Cluster > Services > Loader and click the Configurations tab and then All Configurations. In the navigation pane on the left, choose LoaderServer(Role) > Purge. Then adjust the parameter settings shown in the following figure by referring to Table 1.
    Table 1 Parameters for purging historical Loader data
    Recommended Value
    loader.submission.purge.interval
    Interval for invoking the purge task, in minutes.
    60
    loader.submission.purge.limited
    Number of submissions that are retained during the purge. This prevents historical job records from being totally purged.
    0
    loader.submission.purge.record.max
    Maximum number of records that can be retained in a Loader job. Value 0 indicates that the number is not limited.
    7
    loader.submission.purge.threshold
    Duration for retaining historical records, in hours.
    24
  3. Click Save.
  4. Click Dashboard to go to the Loader service page. Click More and select Restart Service. Verify the identity and click OK. Wait until the restart is successful.
